[mapguide-users] Custom layouts...
Andy Morsell
amorsell at spatialgis.com
Tue Mar 21 13:28:11 EST 2006
I think you could get could it to work. The default viewer uses a frameset
and as long as you know the names of the various frames, you should be able
to target your functions correctly. Take a look in the C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\viewerfiles folder at the
framesetnotaskbar.templ and framesettaskbar.templ files. In some custom
code I have done, I target the hidden scriptFrame and then interact with the
mapFrame for the client-side API.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, March 21, 2006 10:12 AM
Subject: [mapguide-users] Custom layouts...
I have an extremely custom MapGuide implementation that I need to look at
migrating. The application portion isn't all that complex, but the layout
is:
http://enviro.nanaimo.ca/index.cfm?tab_ID=2
<http://enviro.nanaimo.ca/index.cfm?tab_ID=2&content_ID=5> &content_ID=5
Just plugging in the default viewer would lead to a severe reduction in
aesthetics. Does anyone have procedures/guidelines for hacking my own
viewer template? Do I need to make global changes or can I constrain it to
this map?
The site currently supports ActiveX and the Java Viewer, so AJAX is my
target viewer. I think that I should just be able to create a layout
without any surround elements and use that in the main window, but I have a
feeling that the task area and the custom tools are going to be hard to
implement.
Jason
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060321/db4cfdd4/attachment.html
More information about the Mapguide_users
