[mapguide-users] SQL functions in the expression builder?
James Card james.card at calcad.com
Tue Mar 21 14:14:28 EST 2006
On Tue, 21 Mar 2006 10:50:05 -0800, Kori Maleski <km at pat.ca> wrote:
> If I try to label with a decimal column, it is displaying 6 zeroes after
> the decimal - annoying when you try to label contours...
For contours I am using the expression "0+ELEVATION". By adding the value
to zero you force the type to be integer. Note that there must be no
spaces in the expression, and that it must have the zero first
(ELEVATION+0 does not work).
James Card
California CAD Solutions, Inc.
209 578-5580 Voice
209 521-6493 FAX
More information about the Mapguide_users mailing list
