[mapguide-users] "There was an error loading the map"
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 21 20:37:20 EST 2006
Yes, we've seen this problem recently.  The problem occurs if the DWF returned by the server has a lot of resources, and unfortunately there's no good workround for this.  You can reduce the number of resources by having fewer layers and by reducing the number of theme categories for those layers which are themed.
The good news is that the next version of DWF Viewer will have this fixed.  Also, the error itself is harmless (there's no data loss).  It's just annoying...
Walt
	-----Original Message-----
	Sent: Tue 3/21/2006 5:55 PM
	Cc:
	Subject: [mapguide-users] "There was an error loading the map"
	Hi All,
	I am having a problem with a map layer.
	I have a polyline shapefile converted to SDF.
	When it is added to the map, the DWF viewer throws an error while trying to
	load the map.  After clicking "Ok" it will finish loading.  Everything will
	work error free from that point on, so it is only during the initial load of
	the map.
	If I remove the one layer - all is well.
	Autodesk DWF Viewer:
	Unrecognized or unexpected sequence in stream"
	Anybody else run into this?
	Kori Maleski  BSc.
	Senior Technical Consultant
	Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
	TEL
	403.770.1917
	FAX
	877.691.9149
	 TOL
	877.691.9171
	www.pat.ca
	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060321/95cf454d/attachment.bin
More information about the Mapguide_users mailing list
