aclocal warnings Fedora 4 build
WF morrison jagdpup at gmail.com
Wed Mar 22 23:49:16 EST 2006
Apparently there is a conflict with my version of automake (1.9).   I
get the following error with the aclocal command:
[root at jagdpup mapguide-1.0.0]# aclocal
acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
  run info '(automake)Extending aclocal'
  or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
acinclude.m4:12: warning: underquoted definition of MAP_SUBST
acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
acinclude.m4:67: warning: underquoted definition of MAP_GENERATE_MAKEFILES
acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
acinclude.m4:83: warning: underquoted definition of MAP_DEFINE_TYPE_RLIM_T
acinclude.m4:108: warning: underquoted definition of MAP_SUBST_EXPANDED_ARG
acinclude.m4:115: warning: underquoted definition of MAP_EXPORT_ARGUMENTS
More information about the Mapguide_users mailing list
