[mapguide-users] Device space only for lines?
Robert Bray robert.bray at autodesk.com
Thu Mar 23 13:40:04 EST 2006
Ok, this looks like a really useful feature we should have done long
ago. Yes someone please log an enhancement request for this in Project
Tracker and include a reference to these e-mails for the use cases.
Thanks,
Bob
-----Original Message-----
From: Kevin Mayall [mailto:kmayall at agresearch.bm]
Sent: Thursday, March 23, 2006 11:10 AM
Subject: RE: [mapguide-users] Device space only for lines?
I've been wanting this in MG for some time.
Another example: say I have a polygon layer (parcels, zoning, habitats)
and the boundary of the polygon should be interpreted as imprecise -
say, the actual line could be within 10 feet on either side.  I would
want this line to have a 20-foot width, that is defined in ground/map
units.
This avoids the common issue of having users attribute false precision
to boundary locations as they zoom in.  It's a big issue in map use.
KM
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: March 23, 2006 12:06 PM
Yes, for lines and borders.  Should I put in an enhancement request? :)
Lines are most important.  In many cases I want them to show up as a
fixed width.  Two examples:
- At large scales, I want road centrelines to show up at the their
physical width, as defined in the database.  I don't have a polygonal
roads coverage; this allows me to shade the roads.
- I want to be able to do the same with utility pipes.
I can work around this by pre-processing the lines into polygons (using
FME), but it would be much nicer if I could just define a map-units line
width in the application.
Jason
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, March 23, 2006 05:38
Jason,
Do you mean mapping space line width? In that case the answer would be
no. However, this is a feature that can easily be added.
Traian
Sent: Wednesday, March 22, 2006 7:22 PM
Subject: [mapguide-users] Device space only for lines?
Is there any way to define lines in map space instead of device space?
This is going to be a considerable problem for me if not...
Jason
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
