[mapguide-users] Build Oem error on fc4
Dennis Megarry
dennis at myairplane.com
Fri Mar 24 19:20:50 EST 2006
[mapguide-users] Build Oem error on fc4[root at srv4 mapguide-1.0.0]# gcc -v
Reading specs from /usr/lib/gcc/i386-redhat-linux/3.4.3/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-java-awt=gtk --host=i386-redhat-linux
Thread model: posix
gcc version 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)
----- Original Message -----
Sent: Friday, March 24, 2006 6:16 PM
Subject: RE: [mapguide-users] Build Oem error on fc4
You need to tell us the version of g++ you're using...
-----Original Message-----
From: Dennis Megarry [mailto:dennis at myairplane.com]
Sent: Fri 3/24/2006 5:57 PM
Cc:
Subject: [mapguide-users] Build Oem error on fc4
I'm trying to run the build_oem script but it gives me this error:
ACE 5.4: Configuration / Building ..................
make[1]: Entering directory
`/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers/ace'
Makefile:
/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers/ace/Makefile.ace
g++ -W -Wall -Wpointer-arith -pipe -O3 -g -D_REENTRANT -DACE_HAS_AIO_CALL
S -D_GNU_SOURCE -I/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers -DA
CE_HAS_EXCEPTIONS -D__ACE_INLINE__ -DACE_BUILD_DLL -DACE_OS_BUILD_DLL -c -f
PIC -o .shobj/ARGV.o ARGV.cpp
In file included from
/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:2
86,
from
/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers/ace/ARGV.h:24,
from ARGV.cpp:6:
/home/admin/auto/mapguide-1.0.0/Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp
: In member function `void ACE_Unbounded_Queue<T>::delete_nodes()':
:133: error: expected class-name before '(' token
: In destructor `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
:153: error: expected class-name before '(' token
: In member function `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
:223: error: expected class-name before '(' token
make[1]: *** [.shobj/ARGV.o] Error 1
make[1]: Leaving directory
make: *** [all] Error 2
ACE 5.4: Build Successful ..........................
I tried building mapguide afterwards (because it actualy said it was
successful) but got the same error there as well.. Anyone know what I'm
missing?
Dennis
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060324/cc42b73c/attachment.html
More information about the Mapguide_users
