[mapguide-users] login
Traian Stanev
traian.stanev at autodesk.com
Mon Mar 27 09:50:54 EST 2006
Is the MapGuide Server service started? Please check the attached
screenshot to see what I mean.
Traian
-----Original Message-----
From: volunteer at spatiallink.org [mailto:volunteer at spatiallink.org]
Sent: Monday, March 27, 2006 9:44 AM
Subject: RE: [mapguide-users] login
Traian,
There is no mgserver.exe under C:- I am using WebServer Extensions. I
have a MapAgent.exe under ../www/mapagent/.
Harsh
> -------- Original Message --------
> From: "Traian Stanev" <traian.stanev at autodesk.com>
> Date: Mon, March 27, 2006 9:21 am
> To: <users at mapguide.osgeo.org>
> Cc: "Robert Bray" <robert.bray at autodesk.com>, "Dave Wilson"
> <dave.wilson at autodesk.com>
> Hi Harsh,
> The MapGuide server is a service running in addition to your web
server.
> In the task manager, look for mgserver.exe. If that is not running you
> will need to start it manually.
> Traian
> Sent: Monday, March 27, 2006 9:17 AM
> Cc: Robert Bray; Dave Wilson
> Rob,
> ApacheMonitor.exe shows up as running under Task Manager [WIN2003].
> I restart ApacheMapGuide and try to login to login.php, but get the
> following error message:
> "Authentication Failed. Please enter a valid username and password."
> Harsh
> > From: "Robert Bray" <robert.bray at autodesk.com>
> > Date: Sun, March 26, 2006 2:58 am
> > Cc: "Dave Wilson" <dave.wilson at autodesk.com>
> > Harsh, Is the MapGuide Server Service installed and running?
> Sometimes it does not auto-start after install. Bob
> > Sent: Saturday, March 25, 2006 5:38 PM
> > Cc: Dave Wilson
> > Dave/Others-
> > I am trying to install MapGuide OpenSource Web Server Extensions.
> > I tried it on Windows XP Professional on both ports- #8008 with
MS4W
> and #80 withOUT MS4W. I followed the instructions in
> https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf
> for PHP. Then I tried logging-in to ../mapguide/mapadmin/login.php
using
> 'Administrator' and 'admin' [case-sensitive] with both, Firefox and
> Internet Explorer. This leads to an 'incorrect login' error. Apache
> MapGuide service is running during these attempts.
> > I am now trying the same on Windows 2003 Professional Server.
> > Thanks, Harsh -------- Original Message --------
> > From: "Dave Wilson" <dave.wilson at autodesk.com>
> > Date: Fri, March 24, 2006 7:02 pm
> > Could you kindly provide more details please?
> > For example are you logging into the Webadmin php page? For example
> > http://localhost:8008/mapguide/mapadmin/login.php for Apache.
> > Are you getting an error message if so what is it?.
> > Regards,
> > Dave
> > Sent: Friday, March 24, 2006 4:47 PM
> > Subject: [mapguide-users] login
> > username: Administrator
> > password: admin
> > ...do not work even when Apache MapGuide is running [WIN2003].
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Type: image/png
Desc: services.PNG
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060327/119db269/services.png
More information about the Mapguide_users
