[mapguide-users] PHP to ASP - dotnet namespace problems
    Brian Flood
    BFLOOD at SPATIALDATALOGIC.COM
    Tue Mar 28 14:29:32 EST 2006
I had this problem and it looks like the problem had to do with multiple
version of the .Net framework on the server machine. If this is your case,
goto to the properties for the web application, goto the ASPNET tab and
specify the 2.0 Framework. Once I did this, the compilation errors were
fixed...
cheers
brian
_______________________________
Content-Type: multipart/alternative;
	boundary="----_=_NextPart_001_01C6528F.6F60EF64"
Date: Tue, 28 Mar 2006 09:45:42 -0800
Subject: [mapguide-users] PHP to ASP - dotnet namespace problems
Grasping at straws here...
Have you tried doing a repair install on the web extensions?  Go into
Add/Remove Programs, Click on "Change" and then select the repair
option.
Jason
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Tuesday, March 28, 2006 09:34
Subject: RE: [mapguide-users] PHP to ASP - dotnet namespace problems
Jason, I fixed the path as well as moved items around in the path,
rebooted, tested again and again, but nothing seems to fix that error.
Line 19 of the utilityfunctions.aspx is the line that is breaking...
<%@ Import Namespace="OSGeo.MapGuide" %>
is this a resource?  Should I be looking at a specific file that has
this resource? And its path?
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
More information about the Mapguide_users
