[mapguide-users] AW: Error - DWF Viewer Sample Application
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 28 17:06:25 EST 2006
There was just a long thread about this the past two days with subject
"PHP to ASP - dotnet namespace problems".  Read through it carefully and
try everything you find in there.  If you still have problems then let
us know.
-----Original Message-----
Sent: Tuesday, March 28, 2006 4:35 PM
Subject: Re: [mapguide-users] AW: Error - DWF Viewer Sample Application
Even though I checked the following suggestions, I didn't fix the
compilation
error. How can I solve this problem? Please give me some advice. Thank
you.
# Are you using .NET 2.0?
# Did you create a bin folder and copy the MapGuideDotNetApi.dll and
MapGuideUnmanagedApi.dll from the /mapviewernet/bin folder?
# Did you copy the webconfig.ini file from the /www folder to the
/dotnetviewersample folder?
Server Error in '/mapguide' Application.
Compilation Error
Description: An error occurred during the compilation of a resource
required
to service this request. Please review the following specific error
details
and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
not
be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 17: <%@ Import Namespace="System.Collections" %>
Line 18: <%@ Import Namespace="System.IO" %>
Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 20: <script language="c#" runat="server">
Line 21:
Source File: c:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\util
ityfunctions.aspx
Line: 19
View this message in context:
http://www.nabble.com/AW%3A-Error---DWF-Viewer-Sample-Application-t13178
23.html#a3638550
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
