[mapguide-users] WMS questions
Traian Stanev
traian.stanev at autodesk.com
Wed Mar 29 15:20:07 EST 2006
1) No. Currently there is no way to turn off antialiased drawing. You
can enter this as an enhancement request.
2) My guess is that this may be caused by a polygon layer that spans
many of your tiles and is getting clipped to the extent you request,
resulting in the black lines. The WMS serving component uses a map
rendering call that does this kind of clipping. May be we should switch
it to not clip, like what the tiled AJAX viewer uses. Or fix the polygon
clipper to not generate polygon segments that parallel the image bounds.
Anyways, this will be fixed. As a workaround (not a perfect one), you
can try turning off the outline of that polygon layer.
Traian
_____
From: Brian Flood [mailto:BFLOOD at SPATIALDATALOGIC.COM]
Sent: Wednesday, March 29, 2006 3:02 PM
To: 'users at mapguide.osgeo.org'
Subject: [mapguide-users] WMS questions
hello all
1) Is there anyway to turn off anti-alias drawing (per layer
preferably)?
2) I keep getting a solid black line on the left and top edges of images
returned. When tiling requests together (think Google Maps custom
layer), this creates an unwanted grid pattern. Any thoughts?
cheers
brian
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060329/5d9d4790/attachment.html
More information about the Mapguide_users
