AW: [mapguide-users] Consumption of WFS feature requests
Matthias Liechti matthias.liechti at autodesk.com
Wed Mar 29 15:29:03 EST 2006
Hi Chis and Thomas
The problems seem definitively to be related to the "keywords" parameter field in the WFS service properties in MapGuide Studio. Once I fill in values both the GetCapabilities request and the GetFeature request work fine. It works also with the original Server/Wfs/OgcWfsServer.config.awd file therefore I've restored that version.
One point that I would like to mention is that the Browser should be closed and re-opened after applying the changes in the service properties box. Otherwise the script might still throw exceptions.
- Matthias
-----Ursprüngliche Nachricht-----
Von: Chris Claydon
Gesendet: Mi 29.03.2006 20:22
An: Matthias Liechti
Cc:
Betreff: RE: [mapguide-users] Consumption of WFS feature requests
	Hi Matthias,
	Are you still having problems with WFS?
	One client reported the same problem as you, and was able to work around it by setting keywords for each WFS feature source. The problem only occurred if the keyword field was left empty in Studio.
	It should also be possible to edit the template to fix the problem.
	Let me know if you still need help with this.
	Chris Claydon.
  _____
	Sent: Tuesday, March 28, 2006 11:51 PM
	Subject: FW: [mapguide-users] Consumption of WFS feature requests
	Hi Thomas
	Adding the definitions below shows the following results:
	http://127.0.0.1/mapguide/mapagent/mapagent.fcgi?REQUEST=GETCAPABILITIES&SERVICE=WFS
	Invalid argument(s): [1] = "const string&" The string is invalid and cannot be converted.
	Invalid argument(s): [1] = "const string&" The string is invalid and cannot be converted. Exception occurred in method MgUtil.WideCharToMultiByte at line 286 in file c:\build_tux_area\mgdev\common\service\util\Util.cpp
	http://127.0.0.1/mapguide/mapagent/mapagent.fcgi?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=Data/zgn_f
	I’ve installed MGOS 1.0 which was posted on our internal AE share
	- Matthias
  _____
	Sent: Mittwoch, 29. März 2006 00:33
	Subject: RE: [mapguide-users] Consumption of WFS feature requests
	Hi Matthias,
	The descriptions your providing look like it could be a mismatch between the OGC templates and the source code.  Are you getting the source and building, or are these from the downloaded installs?
	Here’s a quick fix to suppress the warnings if you need to move forward, but some further investigation is in order, because this could be symptoms of something else amiss.
	1. Look for the file Server/Wfs/OgcWfsServer.config.awd in your install.  Use a text editor (such as notepad, or vi or the like) to edit this file. (Don’t use a word processor, though!)
	2. Look for the line that reads </Definitions> which is about half way down the file.
	3. Add the following statements before the </Definitions> element, so that you have something that looks like this:
	<Define item=”Feature.Keywords”></Define>
	<Define item=”GetFeature.FeatureCollection”></Define>
	</Definitions>
	This should prevent the error messages from occurring, but like I said, we should figure out why they’re happening on your system in the first place.
	- Thomas
  _____
	Sent: Tuesday, March 28, 2006 2:07 PM
	Subject: [mapguide-users] Consumption of WFS feature requests
	Hi
	I've successfully exposed some WMS layers from MGOS to the public. Now I tried to publish a feature resource to the public through the WFS interface. Unfortunately both getting the capabilities and requesting a features failed. I've used the following Request parameters:
	Get capabilities:
	error message:
	Reference to undefined entity 'Feature.Keywords'. Error processing resource 'http://127.0.0.1/mapguide/mapagent/mapagent.fc...
	      <Keyword>&Feature.Keywords;</Keyword>
	Get Feature:
	error message:
	Reference to undefined entity 'GetFeature.FeatureCollection'. Error processing resource 'http://127.0.0.1/mapguide/mapagent...
	   &GetFeature.FeatureCollection;
	Can anyone give me some hints to successfully set up WFS requests? Does the consumption of WFS feautres already work in Map2007?
	Thanks
	Matthias
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060329/92bd3502/attachment.html
More information about the Mapguide_users mailing list
