[mapguide-users] Botched Install on IIS 6
Andy Morsell
amorsell at spatialgis.com
Fri Mar 31 14:52:48 EST 2006
Add one more item to the list:
ajaxviewer.aspx was not configured as the default document under the
mapviewernet virtual directory. Although, mapviewernet was created and
setup as an application by the installer.
Andy
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, March 31, 2006 11:47 AM
Subject: [mapguide-users] Botched Install on IIS 6
Based on some discussions this morning, I changed a setting a in an IIS 6 /
.NET web extensions install. This setting was to enable Integrated Windows
Authentication on the mapviewerajax virtual directory. I then changed it
back so it was not enabled. This was the only setting I touched in the
entire implementation. After this, I could no longer login to the site via
Studio, but could through the PHP Admin tool. I tried using the repair
option in the web extensions install, and that did not help. I then
uninstalled the web extensions entirely and re-installed and got it working
again. I confirmed that all of the virtual directories had been removed
from IIS by the uninstall prior to reinstalling.
After the reinstall, here are some things I noticed that I had to manually
fix before it work:
* The mapviewerdwf virtual directory was not created
* The application name for the mapguide virtual directory was mapagent
* The mapviewernet virtual directory was not configured as an
application
It looks like the installer has some major issues as others have noted some
of these problems with their installations as well.
Andy Morsell, P.E.
Spatial Integrators, Inc.
<http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060331/3b263b7c/attachment.html
More information about the Mapguide_users
