[mapguide-users] Relationship between enabling selection on layer and tooltip
Butler, Juan P
jpbutler at co.pinellas.fl.us
Mon May 1 15:34:01 EDT 2006
Also, with the tooltip....
I'm not sure if others have a requirement, but I would like to stream
images to the tool tips in the AJAX viewer. I can place an image in the
tool tip if there is an actual image (i.e. <img
src=http://localhost/images/me.gif>) . But I have images that are
stored in the database and I have a page that streams out the images
from the DB (i.e. <img src=http://localhost/getImage.aspx?ID=123>)
The tooltip will blink and blink, but no image appears. If I hold down
on the symbol in the map, the image sometimes appears for a split
second. This function works great in my Google map and I would like to
know if this will be something that we can expect to see in Mapguide.
Thanks.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: Monday, May 01, 2006 2:25 PM
Subject: RE: [mapguide-users] Relationship between enabling selection on
layer and tooltip
Juan,
This is a bug, and it does not depend on the type of layer. The code
that extracts tool tip info is common with the code performing the
selection. This code enforces that a layer is selectable. This is of
course desirable for the selection process, but not for tool tips.
Alain
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Saturday, April 29, 2006 8:10 PM
Subject: [mapguide-users] Relationship between enabling selection on
layer and tooltip
Is anyone else experiencing issues with tooltips on features? For my
parcel polygon layer, if I make the layer non-selectable, the tooltips
will not appear. Once I make the layer selectable, the tooltips come
back. I'm using the AJAX viewer and the layer is linked to a mdb file.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060501/e0b94aef/attachment.html
More information about the Mapguide_users
