[mapguide-users] Build New Library - Make Package
Jason Birch
Jason.Birch at nanaimo.ca
Wed May 3 19:08:29 EDT 2006
The current FME betas (which will turn into the 2006 GB edition) do
support writing to SDF 3.
I haven't scripted Studio yet (it's something that I hope to avoid) but
the API help indicates that there's a ConvertToSdf property of the
ShpLoadProcedure class. Also, you can Execute an existing load
procedure.
Jason
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Wednesday, May 03, 2006 12:24
Subject: RE: [mapguide-users] Build New Library - Make Package
The functionality in the admin page is for making a package FROM an
existing repository. It's essentially an export. The path is just a
folder path within a repository. For example under the root of your
library you have a folder called MyData. In the path field in the admin
page enter MyData and that folder and contents will be exported to a
package.
If you are trying to upload data you can do 1 of 3 things:
1) Use the Studio demo to upload the data via a load procedure and
convert it to SDF or just load it as SHP.
2) Use the Studio demo to start a load procedure, but from the File menu
Save as Package and copy the file to the server packages folder to
upload from the Admin page. This approach is used for large files.
3) Use Studio API calls to generate your own package, but this will only
allow you to upload the SHPs as is because there is no API currently for
converting the SHP's (outside of Studio if I'm not mistaken) to SDF 3.0.
Some users may have already done this scripting and can provide
examples.
I believe it is possible to use FME to create SDF 3.0's from SHPs.
Regards,
Dave
From: Dimitrios Fryganiotis [mailto:dimitrios.fryganiotis at nsl.eu.com]
Sent: Wednesday, May 03, 2006 10:32 AM
Subject: [mapguide-users] Build New Library - Make Package
Hello,
I have downloaded the latest MapGuide Open Source and I have to say that
it is really good software.
However, I am struggling with some of its features. I want to create a
new library and generally to
Make a new Package through the functionality provided in the
administration page. I have a folder
called World and within that folder a couple of XML and Data
files(SDFs). When I give that path to the Folder name e.g
C:\Program Files\MapGuideOpenSource\Server\Temp\World and package name
World it comes up
with the error: Cannot create package World from folder C:\Program
Files\MapGuideOpenSource\Server\Temp\World: Invalid resource name:
That's the first issue, the other is that I don't have original SDF data
files but SHP. I use the SDF Loader to convert them into
SDF and seems to work ok, but is this the correct way for creating short
of Spatial Data sources and putting them into the package?
I would appreciate if somebody has an example of creating a new
Library/Package step by step. I am using an Apache web-server
and PHP for programming language. Thank you very much in advance.
King Regards
Dimitris
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060503/1bb7177e/attachment.html
More information about the Mapguide_users
