[mapguide-users] Unable to select ODBC features
Butler, Juan P
jpbutler at co.pinellas.fl.us
Thu May 4 09:57:14 EDT 2006
Yeah...I posted this a while back. One of the bugs, but I haven't heard
from Autodesk on this. I've had to come up with a workaround which is
to have a layer that is strictly from SDF and select the feature on this
layer. Then the ODBC layer laying on top of it for the tooltips.
- Juan
From: Chris White [mailto:chris.white at keytraffic.com]
Sent: Thursday, May 04, 2006 7:49 AM
Subject: [mapguide-users] Unable to select ODBC features
I am using a ODBC data source (to an access database) that contains
point data that is represented on the a layer as the standard point
symbol. The problem is that I am unable to select these features in the
Ajax viewer. If I either use the selection tool or select with area they
are not selected. The map is set to allow features on that layer to be
selected
Any ideas? Thanks in advance,
Chris
Chris White
Software Architect
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
Mailto: chris.white at keytraffic.com
<mailto:%20chris.white at keytraffic.com>
Web: www.keytraffic.com <http://www.keytraffic.com/>
This e-mail & any attachments are intended only for the use of the
person(s) to whom it is addressed. It may contain information that is
privileged and confidential within the meaning of applicable law. If you
are not the intended recipient, please contact the sender as soon as
possible by return mail or Tel +44 (0) 8451 303040. The views expressed
in this communication may not necessarily be the views held by Key
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060504/5218f34c/attachment.html
More information about the Mapguide_users
