[mapguide-users] Installing mapguide
Traian Stanev
traian.stanev at autodesk.com
Thu May 4 12:16:57 EDT 2006
Were you logged in as root when you did make install? Do you have jpeg
installed (i.e. does /usr/include/jpeglib.h exist)?
Traian
-----Original Message-----
From: Javier de la Torre [mailto:jatorre at gmail.com]
Sent: Thursday, May 04, 2006 12:09 PM
Subject: [mapguide-users] Installing mapguide
I am installing mapguide right now, but I am having some problems
following the instructions on the PDF file.
I am trying to use all the default settings on an Intel with Red Hat 9.
First I installed Apache, Tomcat and PHP (APT) using the provided
package. Everything seems to be fine, the servers are available and
everyhting worked fine.
Then I download the Mapguide server an Mapguider server extensions and
I build the OEMcomponents. This also seems to compile fine.
IMake 1.0: Build Successful ........................
Done building OEM components .......................
Then I go and try to build and install the default configuration:
aclocal I get this:
acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
run info '(automake)Extending aclocal'
or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
acinclude.m4:12: warning: underquoted definition of MAP_SUBST
acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
acinclude.m4:67: warning: underquoted definition of
MAP_GENERATE_MAKEFILES
acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
acinclude.m4:83: warning: underquoted definition of
MAP_DEFINE_TYPE_RLIM_T
acinclude.m4:108: warning: underquoted definition of
MAP_SUBST_EXPANDED_ARG
acinclude.m4:115: warning: underquoted definition of
MAP_EXPORT_ARGUMENTS
libtoolize --force OK
automake --add-missing --copy OK
autoconf OK
./configure OK
make OK
make check OK
make install get into troubles... After lot of messages I start
getting errors, this is the first one:
BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete type
And I can not continue following the instructions :(
Anybody can help?
Thanks in advance.
Javier.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
