[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Thu May 4 12:47:51 EDT 2006
Thanks all,
I finally did a yum install libjpeg-devel and this installed the
requiered libraries.
Seems that I passed this step now :)
It could be interesting to include in the documentation that the
package that is needed is libjpeg-devel. Most people can then do a
up2date or yum or apt-get to install it easily.
Thanks again.
Javier.
On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> You might have to specify --enable-shared as an input to the configure
> script.
> Jason
> -----Original Message-----
> From: Javier de la Torre [mailto:jatorre at gmail.com]
> Sent: Thursday, May 04, 2006 09:36
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] Installing mapguide
> no, there is nothing there...
> Am I installing the correct library? In the documentation it says:
> The libjpeg.so library is required. It is installed by default with most
> Linux distributions. If you do not have it, you can download the source
> from the Independent JPEG Group: www.ijg.org.
> I downloaded from there:
> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> Now I am not sure...
> JAvier.
> On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > Did it put it under /usr/local/include by any chance?
> > Sent: Thursday, May 04, 2006 12:23 PM
> > Yes, I was logged as root.
> > The file /usr/include/jpeglib.h does not exist.
> > I downloaded the jpeg-6b and installed it but does not seems to
> > include this file. It copies others to usr/local/bin.
> > Thanks.
> > > Were you logged in as root when you did make install? Do you have
> > > jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > > Traian
> > > Sent: Thursday, May 04, 2006 12:09 PM
> > > Subject: [mapguide-users] Installing mapguide
> > > Hi,
> > > I am installing mapguide right now, but I am having some problems
> > > following the instructions on the PDF file.
> > > I am trying to use all the default settings on an Intel with Red Hat
> > 9.
> > > First I installed Apache, Tomcat and PHP (APT) using the provided
> > > package. Everything seems to be fine, the servers are available and
> > > everyhting worked fine.
> > > Then I download the Mapguide server an Mapguider server extensions
> > > and I build the OEMcomponents. This also seems to compile fine.
> > > IMake 1.0: Build Successful ........................
> > > Done building OEM components .......................
> > > Then I go and try to build and install the default configuration:
> > > aclocal    I get this:
> > > acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
> > >   run info '(automake)Extending aclocal'
> > >   or see
> > > http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > > acinclude.m4:12: warning: underquoted definition of MAP_SUBST
> > > acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
> > > acinclude.m4:25: warning: underquoted definition of
> > MAP_GEN_CONFIG_VARS
> > > acinclude.m4:67: warning: underquoted definition of
> > > MAP_GENERATE_MAKEFILES
> > > acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
> > > acinclude.m4:83: warning: underquoted definition of
> > > MAP_DEFINE_TYPE_RLIM_T
> > > acinclude.m4:108: warning: underquoted definition of
> > > MAP_SUBST_EXPANDED_ARG
> > > acinclude.m4:115: warning: underquoted definition of
> > > MAP_EXPORT_ARGUMENTS
> > > libtoolize --force OK
> > > automake --add-missing --copy   OK
> > > autoconf    OK
> > > ./configure   OK
> > > make OK
> > > make check OK
> > > make install  get into troubles... After lot of messages I start
> > > getting errors, this is the first one:
> > > BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
> > > BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete type
> > > And I can not continue following the instructions :(
> > > Anybody can help?
> > > Thanks in advance.
> > > Javier.
> > > - To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
