[mapguide-users] Unable to select ODBC features
Ronnie Louie ronnie.louie at autodesk.com
Thu May 4 12:50:16 EDT 2006
A fix was submitted yesterday to address this.  See artifact MG276 in Project Tracker for more details.
Ronnie
-----Original Message-----
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Thursday, May 04, 2006 7:57 AM
Subject: RE: [mapguide-users] Unable to select ODBC features
Yeah...I posted this a while back.  One of the bugs, but I haven't heard from Autodesk on this.  I've had to come up with a workaround which is to have a layer that is strictly from SDF and select the feature on this layer.  Then the ODBC layer laying on top of it for the tooltips.
- Juan
  _____
From: Chris White [mailto:chris.white at keytraffic.com]
Sent: Thursday, May 04, 2006 7:49 AM
Subject: [mapguide-users] Unable to select ODBC features
I am using a ODBC data source (to an access database) that contains point data that is represented on the a layer as the standard point symbol. The problem is that I am unable to select these features in the Ajax viewer. If I either use the selection tool or select with area they are not selected. The map is set to allow features on that layer to be selected
Any ideas? Thanks in advance,
Chris
Chris White
Software Architect
  _____
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
 <mailto:%20chris.white at keytraffic.com> Mailto: chris.white at keytraffic.com
Web:  <http://www.keytraffic.com/> www.keytraffic.com
This e-mail & any attachments are intended only for the use of the person(s) to whom it is addressed. It may contain information that is privileged and confidential within the meaning of applicable law. If you are not the intended recipient, please contact the sender as soon as possible by return mail or Tel +44 (0) 8451 303040. The views expressed in this communication may not necessarily be the views held by Key Traffic Systems Ltd.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060504/f42dda9e/attachment.html
More information about the Mapguide_users mailing list
