[mapguide-users] OnSelection Event?
    Jason Birch
    Jason.Birch at nanaimo.ca
    Fri May  5 03:32:04 EDT 2006
There is an OnSelectionChanged function in the main frame, but it doesn't appear to be documented.
I've just tried playing around with this, and I got the following to work when inserted into the <head> of the ajaxviewersample.php file.  It does not appear to work with the DWF viewer; maybe why it's not documented?  Or it could just be that my code is bad :)
<script type="text/javascript" >
var originalOnSelectionChanged;
var initTimer = setInterval(watchInitialized, 200);
function watchInitialized () {
 try {
  if(ViewerFrame.mapFrame.mapInit)
   clearInterval(initTimer);
   originalOnSelectionChanged = ViewerFrame.OnSelectionChanged;
   ViewerFrame.OnSelectionChanged = MyOnSelectionChangedHandler;
   catch(Exception) {}
function MyOnSelectionChangedHandler() {
   originalOnSelectionChanged ();
   var mapFrame = ViewerFrame.GetMapFrame();
   selCount = mapFrame.GetSelectedCount();
   alert("Selected: " + selCount);
</script>
Subject: [mapguide-users] OnSelection Event?
I suppose there is no onSelectionChanged event like in MG6.5. So this would be done on a onClick? Where would I put the code for this?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060505/7470145e/attachment.bin
More information about the Mapguide_users
