Check if service is running?
Andy Morsell
amorsell at spatialgis.com
Sun May 7 13:07:16 EDT 2006
After having the modified version running on my production server for several
days, I have discovered that my service lockups are not detected by this
script. I did quite a bit more experimentation on my locked up server (I
can lock it up in a two step operation with the FDO raster provider) and
here is what I discovered when the service is in it's locked up state:
I can establish a site connection
I can create a session
I can create a resource service
I can create a feature service
I can create a mapping service
However, as soon as a I try to get a runtime map from an existing map
definition, it fails. But, when it fails, it just stalls with no errors and
nothing is ever returned so a Try, Catch does not do anything.
For now, I'm back to restarting the service every couple of hours through a
scheduled task.
Andy
Andy Morsell wrote:
> Thanks for supplying this to the group Jason. I installed it and made
> some
> tweaks according to my environment and now have it running. I am using a
> scheduled task running every two minutes to check the health. I am also
> writing a log file to an HTML page so will keep an eye on it to see how
> often restarts are necessary.
> For some reason it was not finding my webconfig.ini file in it's own
> directory. I found that I had to make this change to make it work:
> $configFilePath = 'C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini';
> MgInitializeWebTier ($configFilePath);
> For those interested (particularly those running Windows 2000), here are
> the
> tweaks I made. In the second try block, this is the only line:
> exec('c:\restart_MapGuide.bat');
> I already had this batch file created from my older process. The contents
> of that batch file being called are:
> c:\pskill mgserver
> c:\psservice stop "MapGuide Server"
> c:\psservice start "MapGuide Server"
> echo MapGuide restarted %date% %time% "<br>" >>
> c:\inetpub\wwwroot\restart_MapGuide_log.htm
> pskill and psservice can be downloaded from sysinternals.com
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> _____
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Monday, May 01, 2006 11:45 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Check if service is running?
> Well, I made some headway on this, but ran into a bug along the way:
> https://mapguide.osgeo.org/servlets/Scarab?id=MG269
> I could have sworn that I had reported this earlier, but I couldn't find
> it
> in the PT. Basically NET START "MapGuide Server" does not work because of
> a
> name conflict with the "Server" service. Anyone else see this? The SC
> command (possibly another XP/2k3-specific command) appears to work because
> it only accepts the service name.
> You can download a draft PHP CLI health monitoring utility here:
> http://www.jasonbirch.com/files/mghealthmonitor.zip
> Note, this utility is probably XP/Win2k3-specific. Let me know what you
> think.
> Jason
> _____
> Sent: Mon 2006-05-01 3:02 PM
> I wish Windows had the same kind of consistent command line tools that
> unix
> does. I'm trying to think of a way to deal with this across
> Win2k/XP/Win2k3, but short of using the Sysinternals tools I'm drawing a
> blank. ps and grep would really come in handy.
> - The Windows KILL command doesn't appear to have a mechanism for
> identifying the process ID beforehand.
> - The TASKKILL command appears to have everything we need, but it isn't
> available in 2000
> I think I'm going to take the easy way out and use TASKKILL, with
> alternate
> instructions for downloading and using pskill.
> Jason
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/RE%3A-Check-if-service-is-running--t1539555.html#a4270924
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide_users
