I need a HOWTO make a parcel search with php
José Manuel Cerrejón González gis at mapas-sll.com
Mon May 8 11:18:47 EDT 2006
Hi, I want to make from zero, with this info:
   1. I have a Parcel.sdf 3.0 in *XY-M* (Arbitrary X-Y Coordinates
      (Meters)).
   2. IIS 6.0 + PHP.
   3. Parcel.sdf contain a column IDCad with the ID of the parcel.
I've been seeing findparcels.php and I think I must to change some code:
In findparcelfunctions.php:
    $ll84Wkt = 'GEOGCS["LL84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",1]]';
$locationProperty->SetSpatialContextAssociation('LL84');
$sdfParams = new MgCreateSdfParams('LL84', $ll84Wkt, $parcelMarkerSchema);
In findparcels.php:
$map->Open($resourceService, 'Sheboygan');
$featureResId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource");
Any help?
More information about the Mapguide_users mailing list
