[mapguide-users] error providers
carpetascatastro at laplata.gov.ar
Mon May 8 19:02:13 EDT 2006
hi Jason
i downloaded and installed the files following the txt, but it doesn't work. I
don't understand why. The conection data window remaind empty in MapGuide
Studio.
What could it be.
providers.xml
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<FeatureProviderRegistry>
<FeatureProvider>
<Name>OSGeo.SHP.3.0</Name>
<DisplayName>OSGeo FDO Provider for SHP </DisplayName>
<Description>Read/write access to spatial and attribute data in an ESRI SHP
file. </Description>
<IsManaged>False</IsManaged>
<Version>3.0.0.0</Version>
<FeatureDataObjectsVersion>3.0.0.0</FeatureDataObjectsVersion>
<LibraryPath>C:\Archivos de
programa\MapGuideOpenSource\Server\Bin\FDO\ShpProvider.dll</LibraryPath>
</FeatureProvider>
<FeatureProvider>
<Name>OSGeo.SDF.3.0</Name>
<DisplayName>OSGeo FDO Provider for SDF </DisplayName>
<Description>Read/write access to Autodesk's spatial database format, a
file-based personal geodatabase that supports multiple features/attributes,
spatial indexing, and file-locking. </Description>
programa\MapGuideOpenSource\Server\Bin\FDO\SDFProvider.dll</LibraryPath>
</FeatureProvider>
</FeatureProviderRegistry>
<FeatureProvider>
<Name>OSGeo.ODBC.3.0</Name>
<DisplayName>OSGeo FDO Provider for ODBC</DisplayName>
<Description>Read/write access to ODBC-based data store. Supports XYZ point
features.</Description>
programa\MapGuideOpenSource\Server\Bin\FDO\FdoOdbc.dll</LibraryPath>
</FeatureProvider>
thks.
Mensaje citado por Jason Birch <Jason.Birch at nanaimo.ca>:
> Hi Oscar,
> So, you can add an SHP or SDF data source, but not establish a data
> connection? This is probably because out of the box there are no
> providers for basic data connections.
> Because you're on Windows, you can download previews of some (mix of
> proprietary and OS) here:
> https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=35
> <https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=35&exp
> andFolder=35&folderID=4> &expandFolder=35&folderID=4
> There are instructions for integrating these providers into server in
> each zipfile. Careful, because only the OSGeo providers will be
> distributed in source form, the rest will be part of Autodesk MapGuide
> Enterprise.
> Jason
> _____
> From: carpetascatastro at laplata.gov.ar
> [mailto:carpetascatastro at laplata.gov.ar]
> Sent: Mon 2006-05-08 1:38 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] error providers
> My name is oscar im fron to argentina, im work whith gis system.
> Sorry for my english, i have problems install mapgide open source in
> windows
> system + apache, my problem is the conection providers the list is
> empty.
> im check the paths in the .ini but not work
> my S.O. is in spanish is it afect??
> Si alguien habla español podemos armar un foro en español??
> very thanks
> oscar
> This message was sent using IMP, the Internet Messaging Program.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
