[mapguide-users] Problems Building Mapguide with VS 2005
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed May 10 11:24:49 EDT 2006
Did a typo get introduced into one of the build.bat files?  The error
indicates it can't find the "spart_build" label.  Shouldn't that be
"start_build"?
  _____
From: Chris White [mailto:chris.white at keytraffic.com]
Sent: Wednesday, May 10, 2006 10:48 AM
Subject: RE: [mapguide-users] Problems Building Mapguide with VS 2005
Yes I did:
Build -o=c:\SourceCode\mgdev\oem
The source for fdo is in the folder c:\sourceCode\fdo\Opensource_fdo
Thanks
Chris
  _____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: 10 May 2006 15:40
You used the 'build.bat' batch file for building FDO, right?  What
arguments did you pass it?
  _____
Sent: Wednesday, May 10, 2006 10:35 AM
I thought I had - but on more careful inspection I have an error in the
fdo build process.
Build Succeeded
            0 Warning(s)
            0 Error(s)
Time Elapsed 00:00:02.23
            1 file(s) copied.
            1 file(s) copied.
            1 file(s) copied.
            1 file(s) copied.
COPY THIRDPARY HEADER FILES
End thirdparty Build
14:48
The system cannot find the batch label specified - spart_build
There was a build error.
14:48
Any ideas on this one?
Thanks again
Chris
  _____
Sent: 10 May 2006 13:50
Did you build FDO first, as per the build instructions?  GisMessage.h is
an FDO include file.
  _____
Sent: Wednesday, May 10, 2006 6:18 AM
Subject: [mapguide-users] Problems Building Mapguide with VS 2005
I'm attempting to build the Mapguide server solution with VS2005 (on a
Windows 2003 RC2 server) however I'm getting the following error:
Fatel Error C1083: Cannot open include file: 'GisMessage.h'
in Exception.h line 25. Any ideas?
Thanks in advance
Chris
Chris White
Software Architect
  _____
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
Mailto: chris.white at keytraffic.com
<mailto:%20chris.white at keytraffic.com>
Web: www.keytraffic.com <http://www.keytraffic.com/>
This e-mail & any attachments are intended only for the use of the
person(s) to whom it is addressed. It may contain information that is
privileged and confidential within the meaning of applicable law. If you
are not the intended recipient, please contact the sender as soon as
possible by return mail or Tel +44 (0) 8451 303040. The views expressed
in this communication may not necessarily be the views held by Key
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060510/fc424de7/attachment.html
More information about the Mapguide_users mailing list
