[mapguide-users] Autodesk Help - OnSelectionChanged
Kori Maleski
km at pat.ca
Wed May 10 19:28:50 EDT 2006
Hi Jason,
We need to port our applications over from 6.5 to MGO. The function is a generic handler that will work in more than one application. So we prefer it across all of our applications - I totally understand what you mean - but we dont mind the application issue.
That being said - we need Autodesk to identify the issue and how it can be handled.
It worked fine in the Release Candidate - but they modified it a bit since that release.
Cheers,
Kori Maleski BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wed 10/05/2006 4:09 PM
Subject: RE: [mapguide-users] Autodesk Help - OnSelectionChanged
Hi Kori,
I don't think that changing the templates is the right way to be going about this. It means that a single install can only have one application associated with it. I think that hooking the OnSelectionChanged event from the "main" frame might be a more portable way of dealing with this:
http://www.nabble.com/OnSelection-Event--t1561860.html#a4242868
That said, the I wasn't able to get this to work with the DWF viewer either :)
Jason
Subject: [mapguide-users] Autodesk Help - OnSelectionChanged
I need to call a function from the OnSelectionChanged event in the mainframe.templ of the mapviewer/mapagent.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060510/28244b18/attachment.html
More information about the Mapguide_users
