[mapguide-users] Autodesk Help - OnSelectionChanged
Kori Maleski km at pat.ca
Thu May 11 13:12:36 EDT 2006
Juan,
I am in the un-documented realm I think.
I am actually making additions to the mapviewer code.  Here:
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\viewerfiles
Some of it is documented in the Web API as functions you can call from your application.
Others are internal functions.
Cheers,
Kori Maleski  BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Thu 11/05/2006 6:59 AM
Subject: [BULK] RE: [mapguide-users] Autodesk Help - OnSelectionChanged
Hey Kori:
Where did you see the documentation for the "OnSelectionChanged" event?   I'm looking for the event handlers in MGOS that are similar to the ones I used with MG 6.x.   Thanks.
- Juan
Sent: Wednesday, May 10, 2006 6:00 PM
Subject: [mapguide-users] Autodesk Help - OnSelectionChanged
Importance: High
Hi All,
Outstanding issue with some changes:
I need to call a function from the OnSelectionChanged event in the mainframe.templ of the mapviewer/mapagent.
I have a javascript function in the mainframe.templ file itself.
In MGO RC 1:
I called my function from the OnSelectionChanged event - and it worked smooth.
In MGO 1.0:
The code changed for both the AJAX and DWF viewer.
i.e. ajaxmappane.templ and dwfmappane.templ respectively.
The function call from the OnSelectionChanged no longer worked.
I have been fiddling trying to get it working again and have had success with the AJAX viewer but not the DWF Viewer.
For the AJAX viewer:
In the ajaxmappane.templ file;
In the ProcessFeatureInfo() function - I call my function.
Works like a charm.  Everytime I select, the function is executed.
For the DWF Viewer:
It now has that emaprelayer.html with an OnSelectionChanged event.
I try calling my function there:
      parent.parent.myfunction();
- doesn't work.
I try calling it from the OnSelectionChanged event in mainframe.templ.
       myfunction();
- doesn't work.
Doesn't work means stopping IIS, MapGuide Server - editing and saving - then restarting.
Can someone from Autodesk point me in the right direction?
This is critical to mirroring 6.5 functionality in our clients applications.
Cheers,
Kori Maleski  BSc.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060511/3feea363/attachment.bin
More information about the Mapguide_users mailing list
