[mapguide-users] Buffer tool in the AJAX viewer
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri May 12 12:33:38 EDT 2006
Does it depend on which features you're buffering? That could explain
the "random" behavior. I know with Sheboygan there are some parcels
that the buffer code has problems with.
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Friday, May 12, 2006 12:13 PM
Subject: RE: [mapguide-users] Buffer tool in the AJAX viewer
Dave:
I'm using LL84 for the base map and selecting feet as the option in the
buffer page. It was working at one time, but now it's not. I just
can't seem to figure out why it works at times and other times it
doesn't. Same map.
- Juan
_____
From: Dave Wilson [mailto:dave.wilson at autodesk.com]
Sent: Friday, May 12, 2006 10:35 AM
Good day Juan,
are you using different coordinate systems? Does it sometimes work and
sometimes not within the same map?
Regards,
Dave
_____
Sent: Thursday, May 11, 2006 2:00 PM
Well...My buffer problem is back. I'm really not sure what is going
here. Sometimes it functions properly, other times it just creates one
large buffer no matter what the parameters are. Is anyone else
experiencing this?
- Juan
_____
Sent: Wednesday, May 03, 2006 2:39 PM
OK...For some reason, the buffer tool is working now. I'm not sure what
changes and why it would be working now.
There are some issues that I am seeing though. If I create a buffer, it
will not appear until I de-select the object(s) that were being
buffered. Sometimes (in most cases) it will not appear at all. The
only way it does appear, is by me zooming to my initial map view. It
shows up then. Anyone else experiencing this?
- Juan
_____
Sent: Wednesday, May 03, 2006 11:32 AM
I'm running Windows XP.
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, May 03, 2006 11:29 AM
No, they are both running the same build: MapGuide Server (Version
1.0.0.16802).
For what it's worth, the machine it works on with Sheboygan is the Win
2000 box. The application it does not work on in either case is using
the WA State Plane, North Zone, NAD83, feet coordinate system.
Andy
_____
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wednesday, May 03, 2006 8:19 AM
For your Sheboygan sample, do your two machines perhaps have different
builds of MapGuide on them?
Traian
_____
Sent: Wednesday, May 03, 2006 11:15 AM
On both of my installs (one XP, one Win 2000, both .NET) with my
application, whenever I try to do a buffer, I get this error after
hitting the Done button: "Attempted to read or write protected memory.
This is often an indication that other memory is corrupt".
With the sample Sheboygan application running on the same machines, I
see the exact same symptoms you describe below on one machine, but it
works as expected on the other.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
Sent: Tuesday, May 02, 2006 9:14 PM
Subject: [mapguide-users] Buffer tool in the AJAX viewer
Has anyone been able to get the buffering to work in the AJAX viewer.
No matter what value I put in the distance and no matter what unit of
measure I choose, it just makes the same big red buffer that takes up
the whole map. Does this not work in the AJAX viewer?
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060512/ee87d362/attachment.html
More information about the Mapguide_users
