[mapguide-users] BC Albers Projection
Kori Maleski km at pat.ca
Fri May 12 18:33:00 EDT 2006
Here is the BC Albers:
British Columbia Albers Standard Projection
In 1994, the MSRM GIS Working Group chose a standard projection and datum for all spatial data stored in ARC/INFO.
The projection is Albers Equal Area Conic, with parameters of :
Central meridian: -126.0 (126:00:00 West longitude)
Latitude of projection origin: 45.0 (45:00:00 North latitude)
First standard parallel: 50.0 (50:00:00 North latitude)
Second standard parallel: 58.5 (58:30:00 North latitude)
False easting: 1000000.0 (one million metres)
False northing: 0.0
I think the EPSG goes like this:
# British Columbia Albers Standard Projection
<9822> +proj=aea +lat_1=50.0 +lat_2=58.5 +lat_0=45.0 +lon_0=-126.0 +x_0=1000000.0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs  <>
Not sure how to add it to the projection database.If you open up the epsg file in the NAD directory with notepad you could just add manually.  Not sure whether it will work...
Kori Maleski  BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
Sent: Fri 12/05/2006 2:48 PM
Subject: [mapguide-users] BC Albers Projection
Has anyone defined a BC Albers map projection yet, or have any tips on
how to modify the epsg file to add it?
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060512/8df66779/attachment.bin
More information about the Mapguide_users mailing list
