MapGuide application not loading properly inbrowser
Robert Leeman rleeman at eitnl.com
Tue May 16 07:26:11 EDT 2006
Thanks for your reply.  Just to clarify...  I get this application not
loading properly issue on a variety of client paltforms (XP home, XP Pro,
Win 2000, Win 98) so I believe the issue is on the server (Win 2003 Server).
Regards,
Bob Leeman
----- Original Message -----
From: "Yves Bolognini" <yves.bolognini at camptocamp.com>
To: <users at mapguide.osgeo.org>
Sent: Tuesday, May 16, 2006 8:41 AM
Subject: MapGuide application not loading properly inbrowser
> Hello,
> I just happened to have the similar problems with my application.
> IE 6.0 under Windows Server 2003 freezes or even crashes. The exact same
> application works just fine on IE 6.0/Windows XP, IE 6.0/Windows 2000
> and Firefox 1.5.
> Regards,
> Yves
> On mar, 2006-05-16 at 08:35 -0230, Robert Leeman wrote:
>> Hello All:
>> I have a few MGOS web applications deployed using basically the same
>> setup
>> as the Sheboygan AJAX demo.  These applications frequently do not load
>> properly when launched in a Windows browser (tested with IE and Firefox).
>> I
>> get the interface but no map.  Ususally doing a browser refresh one or
>> two
>> times will eventually get the map to load and everything works fine after
>> that.  Has anyone else had this problem?  Is there a fix?  I am using the
>> default MGOS windows install for Apache/PHP on Win Server 2003.
>> Regards,
>> Bob Leeman
>> EIT (NL) Limited
>> St. John's, NL, Canada
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
