[mapguide-users] - Search Function
Berdel, Brian brian.berdel at mcmtrans.com
Thu May 18 09:48:31 EDT 2006
Any idea when this may be corrected?
From: Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
Sent: Monday, May 15, 2006 4:42 PM
Subject: RE: [mapguide-users] - Search Function
Exactly, Thank you.
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: Monday, May 15, 2006 2:39 PM
Brian,
I think you are experiencing this with the DWF viewer. The problem is
that only the features within the current view extent are loaded in the
viewer. The second zoom fails because after you zoomed to the first
feature, the second feature no longer belongs to the view extent, so the
viewer doesn't know about it.  This explains why the second search works
after you zoomed back to the map extent, because the second feature now
belongs to the view extent again. There is a defect logged for this
problem (MG237)
Alain
Sent: Friday, May 12, 2006 9:53 AM
Subject: [mapguide-users] - Search Function
If I use the search function to search for a parcel, it works great.
(The 1st time).
After Searching once I click the parcel and the map zooms to the
selected Parcel. However, if I search again the search still works but
it does not zoom to the parcel If I click on it. I have to zoom to map
extents before performing the second search for it to work. Anyone else
experiencing this?
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Friday, May 12, 2006 10:17 AM
Subject: [mapguide-users] Unable to connect with Studio
Well, I changed over to use the Mapagent.exe in IIS and performance was
poor so I went back to use the isapi_fcgi.dll.   Now I can't connect to
the site using Studio and get "Unable to complete request to Site"
window.  It states "Unexpected error in contacting site URL".   Anyone
run into this or have any suggestions?  I've rebooted many times to no
avail.
Also, in my applications, none of layers show up in the map and they
have question marks on them in the legend.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060518/55221a3c/attachment.html
More information about the Mapguide_users mailing list
