[mapguide-users] Mapguide Server no longer showing in list of services
Dave Wilson dave.wilson at autodesk.com
Thu May 25 16:51:10 EDT 2006
I believe there is a command line option to install the process as a service. From a dos prompt in the server\bin folder you can type mgserver.exe /install.
Try this instead of a repair or reinstall.
Dave
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, May 23, 2006 7:45 AM
Subject: RE: [mapguide-users] Mapguide Server no longer showing in list of services
Well, I'm able to run it interactively via the command line.   I'll just need to see about reinstalling it as a service.
I did get it to repair.  I just started a new install and it then complained about the software already being installed.   But before I clicked OK to that alert, I saw it created a Setup.msi.   I just referenced that one when repairing the server.  It repaired, but didn't bring back the Mapguide service to my service list.
- Juan
  _____
Sent: Tuesday, May 23, 2006 2:03 AM
Subject: AW: [mapguide-users] Mapguide Server no longer showing in list of services
Dear Juan,
I´ve had this problem once before, and as you did I try to repair, but got the same problem as you have. In my case only a reinstall solved this ...
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
  _____
Von: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Gesendet: Dienstag, 23. Mai 2006 04:16
An: users at mapguide.osgeo.org
Betreff: [mapguide-users] Mapguide Server no longer showing in list of services
Well, now all of a sudden, Mapguide does not show up in the list of services and it's not running.   Wondering if anyone has run into this and what they did to solve the problem.  I'm thinking about re-installing the server software...Tried to repair, but it's looking for an installation file that is no longer on the machine.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060525/e2fda4bb/attachment.html
More information about the Mapguide_users mailing list
