[mapguide-users] Building Search based on joined fields
    Campbell, Keith A
    keith.campbell at atkinsglobal.com
    Wed Nov  1 03:54:35 EST 2006
Warren,
This highlighting problem is a bug. A fix has now been submitted - see
artefact MG432 in the Project Tracker. Presumably the next release will
include the fix.
Keith
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: 31 October 2006 19:44
Subject: RE: [mapguide-users] Building Search based on joined fields
Ok...
I have setup a VM with MGOS 1.0.2.
Created the same setup as my work machine.
Now when I create the join to SQL Server , anytime I select a single
parcel, all of the parcels are selected....
Btw, this happens regardless whether the feature class is joined to SQL
Server or an Access database...
Warren
Sent: Monday, October 30, 2006 2:37 PM
Thanks Andy,
On this particular work machine I'm using Enterprise (1.0.0.17804)
I'll set this up at home (or in a VM) and test it later on MGOS 1.0.2.
Thanks again!
Warren
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Monday, October 30, 2006 2:31 PM
I noted the same error under the same circumstances with 1.0.1 and
Enterprise.  I was hoping it was fixed in 1.0.2 (which I have not had
time to work with yet), but it looks like the bug lingers. (you are
using 1.0.2 aren't you?)
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Monday, October 30, 2006 12:20 PM
Subject: [mapguide-users] Building Search based on joined fields
Is it possible to create a search based on a value in a joined field?
I'm getting the following error when I attempt search a joined field:
An exception occurred in FDO component. Invalid identifier name '<Field
Name>'. Exception occurred in method
MgServerGwsGetFeatures.GetMgClassDefinition at line 207 in file
c:\build_tux_area\mgdev\server\src\services\feature\ServerGwsGetFeatures
.cpp
Anybody successfully getting search results from a joined field?
Thanks
Warren Medernach
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
This email and any attached files are confidential and copyright protected. If you are not the addressee, any dissemination of this communication is strictly prohibited. Unless otherwise expressly agreed in writing, nothing stated in this communication shall be legally binding.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061101/901aa2ff/attachment.html
More information about the Mapguide_users
