[mapguide-users] Re: Webstudio upload feature source?
TW twiebe at cityofwinkler.ca
Thu Nov 2 13:05:53 EST 2006
Zak,
Yes, the sdf file I create will upload through webstudio, as long as it is
not to large. I noticed that file sizes that are several MB's will generate
an error and fail to load.
I also noticed if I take a sdf from the sheboygan set and modify it (in map
2007), the webstudio will still allow me to create layers with it and view
it in webstudio.
However, if I take a sheboygan sdf "islands" and delete out all the features
and add my own features, webstudio will not allow me to create a layer.
In the layer menu I can select the feature datasource, but cannot specify
the geometry field or the Feature geometry in the Feature data selection.
I also noticed I cannot change the color selection for layers in the style
menu. I can open the style area and select the fill and line style but
cannot change the color using the button on the left.
I hope this makes sense
Tim
Zak James wrote:
> Tim,
> During development, we tested the upload facility only with the
> default apache web server so IIS may be involved in your problems. Can
> you verify that the sdf file is present in the repository after
> upload?
> zak
> On 11/1/06, METRO3 <twiebe at cityofwinkler.ca> wrote:
>> It appears now that I can upload a datasource. I had to reinstall the
>> server
>> and extensions 1.0.2.
>> However, even though I can upload the data,  when I try to create a layer
>> from the uploaded sdf data. I am unable to select the featureclass or
>> geometry to setup the layer.
>> Is there criteria for creating sdf3? Should I consider shapefiles?
>> I am creating a my sdf3 in Map 2007 my projection is NAD83 UTM.
>> Using IIS5 for the server.
>> THanks
>> Tim
>> Paul Spencer-2 wrote:
>> > Tim,
>> > there were some problems with the original implementation of the
>> > upload facility in webstudio.  These were fixed recently in the trunk
>> > but I don't know if those fixes made it into 1.0.2 release.
>> > Can you let us know a bit about your configuration (server, web
>> > server, version) and any error messages you are getting?
>> > Cheers
>> > Paul
>> > On 31-Oct-06, at 3:51 PM, Tim Wiebe wrote:
>> >> I am new to working with mgos, but can someone tell me why I can't
>> >> upload my own sdf3 or shp through webstudio?
>> >> Am I missing something obvious?
>> >> Thanks
>> >> Tim
>> > |Paul Spencer                          pspencer at dmsolutions.ca    |
>> > |Chief Technology Officer                                         |
>> > |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> > For additional commands, e-mail: users-help at mapguide.osgeo.org
>> View this message in context:
>> http://www.nabble.com/Webstudio-upload-feature-source--tf2548311.html#a7116223
>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
View this message in context: http://www.nabble.com/Webstudio-upload-feature-source--tf2548311.html#a7142342
More information about the Mapguide_users mailing list
