[mapguide-users] Properties pane not displaying Web API
 generated selection properties [No Viruses detected]
    Tom Chadwin
    tom.chadwin at nnpa.org.uk
    Mon Nov  6 07:11:47 EST 2006
Hi Bill
Thanks for the reply. I have various properties checked to display for
this layer in MG Studio. When I use the mouse in my application to click
on a feature, those properties do indeed display. The problem only
occurs when I create a selection programmatically and send it to the
map. The feature is highlighted on the map, but the properties pane does
not show the properties.
I am wondering whether the problem is that I am connecting to the
feature source to make the selection, rather than the instance of the
feature source which is used in the layer on the map. Could that be the
problem? If so, how can I create a selection on an existing displayed
layer on the map?
Any ideas?
Thanks
Tom
Tom Chadwin
ICT & Web Development Officer
Telephone: 01434 611530
Mobile:
Fax: 01434 611677
Email: tom.chadwin at nnpa.org.uk
Web : www.Northumberland-national-park.org.uk <http://www.Northumberland-national-park.org.uk>
<http://www.northumberland-national-park.org.uk/>
____________________________________________________________________________
IMPORTANT NOTICE - Disclaimer - November 6, 2006 - REF Email-200611-00041249.
If you have received this e-mail in error or wish to read our e-mail disclaimer statement and monitoring policy, please refer to the statement below or contact the sender.
This communication is from Northumberland National Park Authority (NNPA).The Authority's head office and principal place of business is Eastburn, South Park, Hexham, Northumberland, NE46 1BS, United Kingdom.This communication and any attachments contain information which is confidential and may also be privileged. It is for the exclusive use of users at mapguide.osgeo.org. If you are not the intended recipient(s) please note that any form of disclosure, distribution, copying or use of this communication or the information in it or in any attachments is strictly prohibited and may be unlawful. If you have received this communication in error, please return it with the title "received in error" to "it.security at nnpa.org.uk" then delete the email and destroy any copies of it.
E-mail communications cannot be guaranteed to be secure or error free, as information could be intercepted, corrupted, amended, lost, destroyed, arrive late or incomplete, or contain viruses. We do not accept liability for any such matters or their consequences. Anyone who communicates with us by e-mail is taken to accept the risks in doing so.
Any views or opinions presented are solely those of the author and do not necessarily represent those of NNPA.Contractors or potential contractors are reminded that a formal Order or Contract is needed for NNPA to be bound by any offer or acceptance of terms for the supply of goods or services Although this email and any attachments are believed to be free of any virus or other defects which might affect any computer or IT system into which they are received, no responsibility is accepted by the NNPA for any loss or damage arising in any way from the receipt or use thereof. Computer systems of this Authority may be monitored and communications carried out on them recorded, to secure the effective operation of the system and for other lawful purposes.
-----Original Message-----
From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Sent: 06 November 2006 11:16
Subject: RE: [mapguide-users] Properties pane not displaying Web API
Tom,
The LayerDefintion XML file needs to explicitly list the name of each
property that you want to display in the properties pane (under the
PropertyMapping element).  If you are using MapGuide Studio, use the
"Feature Data Setup" portion of the Layer Editor UI and check the
checkboxes in the "Properties displayed in the Viewer" list.
Bill
From: Tom Chadwin [mailto:tom.chadwin at nnpa.org.uk]
Sent: Monday, November 06, 2006 4:30 AM
> I am generating a selection in the Task pane, and then passing that
> selection to the Map frame and zooming the Map frame to the selection.
> The selection seems to be working, since the point turns blue on the
> map, and the status bar says 1 object selected. However, that
> feature's properties are not being displayed in the Properties pane.
> The message "None Selected" disappears, and the Name and Value column
> headings appear, but with no values listed below them.
> Is there something else I should be doing to get the list of
> properties to display? If I manually click on the feature, the
> properties display in the Properties pane correctly.
Can anyone help with this?
Thanks
Tom
Tom Chadwin
Mobile:
Fax: 01434 611677
____
Email-200611-00041076.
any copies of it.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
