[mapguide-users] web extensions - iis/.net
Andy Morsell amorsell at spatialgis.com
Mon Nov 6 11:30:49 EST 2006
What operating system are you using?  Does Studio work in map preview mode?
Andy
  _____
From: Knight, Gregory [mailto:Gregory.Knight.bra at cityofboston.gov]
Sent: Monday, November 06, 2006 7:52 AM
Subject: [mapguide-users] web extensions - iis/.net
I just did an MGOS 1.0.2 install on a new machine and am having a hard time
getting the web server extensions working.
The mapagent (fcgi) and site administrator are both working properly.
As far as the extensions go, the virtual directories (mapviewerajax and
mapviewerdwf) both appear to have been created properly by the installer -
as applications, with the proper default document, etc.
However, when I try try to reference a test web layout via ajaxviewer.aspx
or dwfviewer.aspx, I get 404 page not found errors.
I recall this being somewhat elusive last time I did an install as well.
but I managed to get it working.  No such luck this time around.
Any ideas here?
Greg
  _____
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061106/41817b0b/attachment.html
More information about the Mapguide_users mailing list
