[mapguide-users] perfomance test
Haris Kurtagic
haris at sl-king.com
Mon Nov 6 17:07:31 EST 2006
Hi Jason,
I checked again about this slow attributes fetching, and it was poor
perfomance in provider.
I have corrected it so this time instead of 18 sec is 6 sec.
btw:
Problem was that FDO fetch properties using property name and than you
need to use strings to find right index in query result set.
I forgot about that one, I mantioned that already on fdo dev list but
forgot to optimize in provider. (Now using hash maps for quicker finding
match)
To allow index based access to properties would be my first fdo rfc when
rfc's starts for fdo :).
Haris
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Sunday, October 29, 2006 11:18 PM
Subject: RE: [mapguide-users] perfomance test
Haris,
Those are some really interesting results. I'd like to see what happens
with spatial index optimisation, but I am mostly wondering why it took
so much longer to pull all features/attributes, where index optimisation
would not have any effect. Was the database server running on the same
box as MapGuide? I'd also like to see what happens with some attribute
filters against a database that has proper column indexes created on it.
What I found most interesting though is that you're working on some
commandline tools for FDO. That is something that is sorely needed. An
fdo2fdo tool would be nice too. Does Mateusz know that you're working
on this? He was looking for some schema-ized data to test the PostGIS
provider against a couple days ago and I didn't have any. I'd also love
to see the same kind of performance comparisons run against the PostGIS
provider when it's available, and some profiling run against the code to
see where most of the time is being spent (in fdo, network, or
database).
Jason
P.S. This kind of comparison might be OK if you are comparing the King
provider's performance against the SDF provider's performance, but be
careful about publishing performance tests for Oracle. Their corporate
lawyers don't like this kind of thing at all. Apparently there's a
clause in the EULA...
Sent: Sunday, October 29, 2006 13:58
Subject: [mapguide-users] perfomance test
Test case 1: No geometry filter, Fetch all attributes
SDF 0.937
SHP 8.531
10GR2 18.172
XE 18.500
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061106/fa227f96/attachment.html
More information about the Mapguide_users
