[mapguide-users] External Layers from WMS
Andy Morsell
amorsell at spatialgis.com
Mon Nov 6 17:56:05 EST 2006
It looks like you (or whoever published the WMS data) is missing the
<BoundingBox> metadata so MGOS does not know what the extent of the data is.
If you author an MGOS layer from that WMS server datasource, you can then
define a map and enter manual Initial View coordinates into the map
definition. These values got me in the ballpark and I was then able to view
data:
Lower left: -124,48
Upper right: -123,56
Andy Morsell, P.E.
Spatial Integrators, Inc.
ttp://www.SpatialGIS.com
-----Original Message-----
From: Jim O'Leary [mailto:joleary.public at gmail.com]
Sent: Monday, November 06, 2006 12:38 PM
Subject: [mapguide-users] External Layers from WMS
I have been able to use the WMS FDO to create a data connection in Studio
to:
http://libcwms.gov.bc.ca/wmsconnector/com.esri.wsit.WMSServlet/ogc_layer_ser
vice?REQUEST=GetCapabilities
I have made a layer using this data connection as the feature source in
Studio. Doing this creates a list box of layers in the Layer Editor in
Studio, the same ones that show up when you use the Gaia browser. I chose
this one:
BC_BASEMAP_LINES_5KM_water
which I can see quite clearly in Gaia. However, it does not show up in the
Preview screen in MGE. I note that the scale is rather large, namely:
1000000000000
However, making the scale smaller does not produce any output.
I added this layer to a map and I noticed that the coordinates on Gaia are
quite different than on the map, so I set them as in Gaia, 143,183, 181,
901, 1,918,550, 1,733,050. However, no matter how I zoom, it doesn't show
up.
I think our WMS configuration is correct, as our server serves up layers to
the Gaia browser. However, external layers do not show up in MGE. Any
suggestions?
Thanks
View this message in context:
http://www.nabble.com/External-Layers-from-WMS-tf2584912.html#a7206650
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
