[mapguide-users] RE: mark symbol action
Farah
farah at egovernments.org
Tue Nov 7 07:28:32 EST 2006
If you are creating the marker layer as per the developer guide method, you
should be referring to a xml file while creating the layer right? In that
file , make the necessary changes. I am attaching some sample code.
Do you mean , is it possible to have links to other pages in the tooltip? I
am not sure about that. I havent tried it out.Will let you know if I find
out..:-)
You can load images into the tooltip though.
regards
farah
-----Original Message-----
Sent: Tuesday, November 07, 2006 5:24 PM
Subject: [mapguide-users] RE: mark symbol action
Thanx for the reply, but can you explain more in detail..
you mean i should edit the LayerDefinition-1.0.0.xsd file is it?
i create the mark symbol by following developer guide method.
is that possible to create a tooltip where another web pages is being loaded
into the tooltip.
just like google map.when you search one particular places it will show a
tooltip where contains the
respective place information, as well as some other map features such as
"What's near by", "how to get here", etc.
I am looking forward for the reply, and thank you for the guidance
Regards,
Kencana
Farah-2 wrote:
> Hi,
> You need to set the url in the layer.xml file. Say for example:
> <Url>'http://www.yahoo.com'</Url>
> Regards
> Farah
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Monday, November 06, 2006 2:32 PM
> Subject: [mapguide-users] mark symbol action
> hi all,
> is that possible to embed an action to a mark symbol like invoke url
> action?
> regards,
> Kencana
> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7195302
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/mark-symbol-action-tf2581167.html#a7217017
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061107/7032ec30/parcelMarker.xml
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061107/7032ec30/findparcelfunctions.obj
More information about the Mapguide_users
