[mapguide-users] RE: RE: mark symbol action
    Andy Morsell
    amorsell at spatialgis.com
    Wed Nov  8 00:23:05 EST 2006
Line breaks don't work in the AJAX viewer but do with the DWF viewer.  This
is as known bug and has been logged in Project Tracker.
Andy
-----Original Message-----
Sent: Tuesday, November 07, 2006 9:19 PM
Subject: [mapguide-users] RE: RE: mark symbol action
I want to ask something..in the label..is that possible to put line
break?coz I have try to use \n,<br> it doesn't work at all..instead of
breaking the line it print out the text...
the following is the coding
<Label>
            <Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
	    						<SizeX>0.3</SizeX>
	    						<SizeY>10</SizeY>
<Text>concat('Address:', concat('<br/>',Address))</Text>
<FontName>Arial</FontName>
<ForegroundColor>FF000000</ForegroundColor>
<BackgroundColor>FFFFFFFF</BackgroundColor>
<BackgroundStyle>Transparent</BackgroundStyle>
<HorizontalAlignment>'Center'</HorizontalAlignment>
<VerticalAlignment>'Baseline'</VerticalAlignment>
          </Label>
I hope you can help me out from this problem...Thank you
Regards,
Kencana
Farah-2 wrote:
> Hi,
> If you are creating the marker  layer as per the developer guide
> method, you should be referring to a xml file while creating the layer
> right? In that file , make the necessary changes. I am attaching some
> sample code.
> Do you mean , is it possible to have links to other pages in the tooltip?
> I
> am not sure about that. I havent tried it out.Will let you know if I
> find
> out..:-)
> You can load images into the tooltip though.
> regards
> farah
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tuesday, November 07, 2006 5:24 PM
> Subject: [mapguide-users] RE: mark symbol action
> Hi,
> Thanx for the reply, but can you explain more in detail..
> you mean i should edit the LayerDefinition-1.0.0.xsd file is it?
> i create the mark symbol by following developer guide method.
> is that possible to create a tooltip where another web pages is being
> loaded into the tooltip.
> just like google map.when you search one particular places it will
> show a tooltip where contains the respective place information, as
> well as some other map features such as "What's near by", "how to get
> here", etc.
> I am looking forward for the reply, and thank you for the guidance
> Regards,
> Kencana
> Farah-2 wrote:
>> Hi,
>> You need to set the url in the layer.xml file. Say for example:
>> <Url>'http://www.yahoo.com'</Url>
>> Regards
>> Farah
>> Sent: Monday, November 06, 2006 2:32 PM
>> Subject: [mapguide-users] mark symbol action
>> hi all,
>> is that possible to embed an action to a mark symbol like invoke url
>> action?
>> regards,
>> Kencana
>> View this message in context:
>> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7195302
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/mark-symbol-action-tf2581167.html#a7217017
> <?xml version="1.0" encoding="UTF-8"?> <LayerDefinition
> version="1.0.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
>   <VectorLayerDefinition>
>     <ResourceId></ResourceId>
>     <FeatureName>ParcelMarker</FeatureName>
>     <FeatureNameType>FeatureClass</FeatureNameType>
>     <PropertyMapping>
>             <Name>NGO_NAME</Name>
>             <Value>1.Name:</Value>
>     </PropertyMapping>
>     <PropertyMapping>
>             <Name>NGO_ADDRESS</Name>
>             <Value>2.Full Address:</Value>
>     </PropertyMapping>
>     <PropertyMapping>
>                 <Name>ORG_TYPE</Name>
>                 <Value>3.Type</Value>
>     </PropertyMapping>
>     <Geometry>Location</Geometry>
> <Url>concat('http://localhost:8008/mapguide/iwp/details.jsp?Id=&a
> pos;, concat("NGO_ID", concat('&SESSION=',
> "SESSION_VAL")))</Url>
>     <ToolTip>concat( 'Organisation : ', concat(NGO_NAME, concat( '
> .\nAddress: ' ,concat( NGO_ADDRESS,concat (' .\nType:
> ',ORG_TYPE)))))</ToolTip>
>     <VectorScaleRange>
>     <MinScale>100000</MinScale>
>       <MaxScale>35000000</MaxScale>
>       <PointTypeStyle>
>         <DisplayAsText>false</DisplayAsText>
>         <AllowOverpost>false</AllowOverpost>
>         <PointRule>
>           <LegendLabel></LegendLabel>
>           <Label>
>             <Unit>Points</Unit>
>             <SizeX>0.3</SizeX>
>             <SizeY>5</SizeY>
>             <Text></Text>
>             <FontName>Verdana</FontName>
>             <BackgroundStyle>Ghosted</BackgroundStyle>
>           </Label>
>           <PointSymbolization2D>
>             <W2D>
>               <Unit>Millimeters</Unit>
>               <SizeX>7</SizeX>
>               <SizeY>7</SizeY>
>               <W2DSymbol>
<ResourceId>Library://Arghyam/4.SYMBOLS/BasicSymbols.SymbolLibrary</Resource
Id>
>                 <LibraryItemName>PushPin</LibraryItemName>
>               </W2DSymbol>
>             </W2D>
>           </PointSymbolization2D>
>         </PointRule>
>       </PointTypeStyle>
>     </VectorScaleRange>
>      <VectorScaleRange>
>             <MaxScale>100000</MaxScale>
>             <PointTypeStyle>
>               <PointRule>
>                 <Label>
> 		    <Unit>Points</Unit>
> 		    <SizeX>0.4</SizeX>
> 		    <SizeY>7</SizeY>
> 		    <Text>NGO_NAME</Text>
> 		    <VerticalAlignment>'Top'</VerticalAlignment>
> 		</Label>
> 	    <W2D>
> 	      <SizeX>7</SizeX>
> 	      <SizeY>7</SizeY>
> 	      <W2DSymbol>
Id>
> 	      </W2DSymbol>
> 	    </W2D>
> 	</PointRule>
>       </PointTypeStyle>
>       </VectorScaleRange>
>   </VectorLayerDefinition>
> </LayerDefinition>
http://www.nabble.com/mark-symbol-action-tf2581167.html#a7232946
More information about the Mapguide_users
