[mapguide-users] Permissions problem...
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Nov 8 05:55:42 EST 2006
Thanks.  In the artifact please include the final diagnosis below.
-----Original Message-----
From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
Sent: Wednesday, November 08, 2006 4:37 AM
Subject: Re: [mapguide-users] Permissions problem...
Sounds about right......at least I know I'm not missing something
obvious. I'll submit an artifact...
Andrew
Walt Welton-Lair wrote:
> I tested this a little more, and here's what I found.
> When opening a web layout using AJAX viewer, the login prompt appears
> immediately, before *any* server request is even made.  The first
> server operation then ends up being an authentication request
> (OpAuthenticate).  After this come the requests for resources - the
> web layout, etc.  These succeed because we have provided credentials.
> When opening a web layout using DWF viewer, the behavior is
> different.  There's a couple of authentication requests that get made
> using "anonymous" user, but no login prompt has yet been displayed.
> Then comes a request to get the web layout resource, again using
> "anonymous".  This fails because user "anonymous" does not have access
> to the library.  The browser then displays the exception message.
> At this point the web layout hasn't been loaded and DWF Viewer hasn't
> even entered into the picture.  So this is a MapGuide web tier
issue...
> Walt
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, November 07, 2006 6:29 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Permissions problem...
> Ya, that's sort of what I figured was happening....that it's not
> asking me to log in, because it doesn't have permission to ask...which
> is a bit silly. If that's the case, then it's a fairly annoying
bug....
> Andrew
>> So it's a question of order.  Should MapGuide first authenticate
>> before it tries to access the resource (and find out that you don't
>> have permission)?  It looks like it does it the other way - it checks
>> whether you have permission before authenticating.  I don't know the
>> right answer.
>> I do know that the DWF Viewer code which handles the HTTP request
>> knows nothing about MapGuide and doesn't know what to do with the
>> permission denied response.
>> Walt
>> *Sent:* Tuesday, November 07, 2006 6:15 PM
>> Ah...sorry. I should have posted the error that it gives me.....When
>> I try to use the DWF Viewer, this is what I get:
>> Permission denied to resource: Library://test/
>> Permission denied to resource: Library://test/ Exception occurred in
>> method MgResourceHeaderManager.CheckPermission at line 2495 in file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
HeaderManager.cpp
>> Andrew
>>> So DWF Viewer doesn't prompt for credentials.  Do you get back any
>>> data or does it just sit there?
>>> Ultimately DWF Viewer simply makes a Mapping Service GetMap HTTP
>>> request via WinINet.  It prompts for credentials when it gets a 401
>>> response to that initial request, and then resubmits the GetMap
>>> request.  If it just sits there that means it didn't get a 401
>>> response and it thinks it's done.
>>> Walt
>>> *Sent:* Tuesday, November 07, 2006 4:53 PM
>>> *Subject:* [mapguide-users] Permissions problem...
>>> I've got a project that I want to password protect....I've given a
>>> specific MapGuide User read permissions to my library (removed
>>> 'Everyone', and added 'Administrator' as read/write as well). What's
>>> happening now is that the DWF viewer isn't asking me to log in. If I
>>> change my URL to use the AJAX viewer, it works fine (asks me to log
>>> in, and then works as it should). So, for example:
>>> http://host/mapguide/mapviewerdwf/?WEBLAYOUT=.....   ----This does
>>> NOT work
>>> http://host/mapguide/mapviewerajax/?WEBLAYOUT=.....   ----This DOES
work
>>> This happens on any PC that I've tested it on. Am I missing
>>> something here, or is this a bug? I'm using v1.0.2.17861 (the latest
>>> release).
>>> Andrew
>>> 	*Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
