Rename Layers and keep alive all connections
    Axel Dörr
    a.doerr at doerrib.de
    Fri Nov 10 07:36:13 EST 2006
Freitag, 10.11.2006
Hello List,
i want to rename several layers (geometry) within a project in a way, that all the connections keep alive to the data which are create with the import of original data, and later on when i created a map, etc.
This is necessary because i distribute maps via wms an the wms-client on the other side uses of course the
layernames within mgo server and not the names i introduced in the assembly of the map within studio.
And now i´m looking for a smart solution to do this. Otherwise i have to go the long way and reload
everthing and give a more usefull, in this case shorter name.
Does someone have a proposal around this problem to solve?
Thanks and regards,
Axel
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061110/9fd4a659/attachment.html
More information about the Mapguide_users
