[mapguide-users] Sheboygan not seen in administrator's 'load package'
Andy Morsell amorsell at spatialgis.com
Fri Nov 10 11:46:43 EST 2006
Are you copying the .mgp file into the same "Packages folder" as defined
under Configure Services in MapGuide Administrator?
Andy
  _____
Sent: Friday, November 10, 2006 6:07 AM
Subject: [mapguide-users] Sheboygan not seen in administrator's 'load
package'
Hello,
Installed MG (version 1.0.2.17861) and tested pursuant to Documentation-'
Installing and configuring on windows'.  All seems fine so far.  My problem
is trying to load sample data package Sheboygan pursuant to
Documentation-'Installing sample data and viewer sample application'.  The
Sheboygan down load entitled 'Sheboygan .mgp' is apparently zip, I've put it
in the correct location, renamed its extension to .mgp, and yet in the 'Load
Packages section' it still is not listed. It appears that for some reason it
is not recognized. I have tried on 2 machines with same results. I think its
something rather simple that I am just missing. Appreciation in advance.
Jay
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061110/bd702ddc/attachment.html
More information about the Mapguide_users mailing list
