[mapguide-users] Use Oarcle XE with Autodesk MAP, MapGuide and King.Oracle provider
Haris Kurtagic
haris at sl-king.com
Sat Nov 11 04:08:14 EST 2006
Thank you.
Instant client is installed by copying those 4 Oracle files anf 3
King.Oracle files into the FDO\bin folder of MAP
If you think for MapGuide the procedure would be same, copy 3
King.Oracle and 4 Oracle files into same folder and edit providers.xml,
same as for MAP.
Is that what you think that I should add clip for?
Haris
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Saturday, November 11, 2006 6:26 AM
Subject: Re: [mapguide-users] Use Oarcle XE with Autodesk MAP, MapGuide
good work haris, 'THE' best tutorial for beginers,
Think you need to mention the installation of instant client or add a
clip to this movie ?
Shailesh
----- Original Message -----
<mailto:haris at sl-king.com>
To: <users at mapguide.osgeo.org> <mailto:users at mapguide.osgeo.org>
Cc:
Date: Friday, November 10 2006 07:48 PM
Subject: [mapguide-users]
provider
Here is flash movie demonstrating how you cane use all this
stuff together.
Idea of movie is to show hot to Install Oracle XE, Transfer SHP
data to it, Edit and Query using Autodesk MAP and MapGuide.
http://www.sl-king.com/fdooracle/KingOracleXE/MapOracleXeKingOracle.html
I hope someone will find this useful and I would appreciate if
you share with me your thoughts if this kind of movies are right way to
share information's.
Demo uses latest provider King.Oracle v0.4.4
www.sl-king.com/fdooracle and Fdo2Fdo v0.2.3 www.sl-king.com/fdo2fdo
Haris <http://www.sl-king.com/fdooracle/>
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061111/e3490546/attachment.html
More information about the Mapguide_users
