[mapguide-users] SDF into DWG or SHP
Brad Nesom kidsmake6 at msn.com
Mon Nov 13 14:49:38 EST 2006
Seems to be some holes here. Dwgtosdf3.arx only works with classified dwgs.
Using the tools in the display manager only works with one layer at a
time(no append). So one of the nice features of sdf3 is the multiple feature
classes in one file. Does anyone own one of these files? The only source it
could have come from is a classified dwg. Is that correct? I am not wanting
to use the sdf format except that I have considered it for "sending" data to
other autodesk users/requestors. Another note: I have had a bulk copy
running for 4 hrs now. The original data arcsde is approx 40MB. My sdf
output is now at 82MB.
hmm
  _____
Sent: Monday, November 13, 2006 10:50 AM
Subject: RE: [mapguide-users] SDF into DWG or SHP
Map 2007 will import/export either version of sdf.
Depending on where you select the import/export from.
The file pulldown or the map pulldown or the commandline _MAPSDFIN is the
sdfv2. (
<mk:@MSITStore:C:/PROGRA~1/AUTODE~1/help/acmap.chm::/WSfacf1429558a55de7bedc
1019295baf0-7288.html> MAPIMPORTMAPGUIDE (Same as MAPSDFIN))
<mk:@MSITStore:C:/PROGRA~1/AUTODE~1/help/acmap.chm::/WS73099cc142f487559a28e
8107bdfefbd9-669d.html> MAPEXPORTMAPGUIDE (Same as MAP2SDF))
>From the display manager select the one layer you want an sdf for. Select
tools export layer. ( cannot find a command line or api version of this
other that the below.)
http://images.autodesk.com/adsk/files/dwgtosdf3.pdf
I assume that SDFLoader will not come over to the MGOS/MGENT from the 6.5
realm. (As it presently only does sdf2)
  _____
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Monday, November 13, 2006 9:18 AM
Subject: Re: [mapguide-users] SDF into DWG or SHP
Maciej
What version of SDF, autodesk Map will import SDFv2 to dwg, not sure about
SDF +3 files
Maciej Skorczewski <maciej.skorczewski at procad.pl>
To:
<users at mapguide.osgeo.org>
Date:
Sunday, November 12, 2006
Subject:
Hi
Sorry if this post is not in topic of this group but i think that
someone can know that.
Problem is: Is it posible to convert SDF files into DWG or SHP (so can i
edit it ex in CAD?)
Maciej Skorczewski
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061113/f202c9ff/attachment.html
More information about the Mapguide_users mailing list
