[mapguide-users] SDF into DWG or SHP
Jason Birch
Jason.Birch at nanaimo.ca
Mon Nov 13 17:13:48 EST 2006
Hi Brad,
Safe Software's FME also allows you to write to multiple feature classes in SDF. Send me a note offline if you're interested in me sending you a sample.
I'm not sure if Haris' fdo2fdo has the ability to create multiple feature classes during transfer yet. When I initially tried it it has problems because the SDF schema couldn't be redefined to add additional tables.
Jason
Sent: Mon 2006-11-13 11:49 AM
Subject: RE: [mapguide-users] SDF into DWG or SHP
Seems to be some holes here. Dwgtosdf3.arx only works with classified dwgs. Using the tools in the display manager only works with one layer at a time(no append). So one of the nice features of sdf3 is the multiple feature classes in one file. Does anyone own one of these files? The only source it could have come from is a classified dwg. Is that correct? I am not wanting to use the sdf format except that I have considered it for "sending" data to other autodesk users/requestors. Another note: I have had a bulk copy running for 4 hrs now. The original data arcsde is approx 40MB. My sdf output is now at 82MB.
hmm
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061113/96203b1d/attachment.bin
More information about the Mapguide_users
