[mapguide-users] Custom Symbols
Campbell, Keith A
keith.campbell at atkinsglobal.com
Thu Nov 16 10:36:14 EST 2006
Traian,
Thanks for the reply. I have discovered this for myself. Some don't
display in the Studio previews, but do display in the map.
Keith
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: 16 November 2006 14:47
Subject: RE: [mapguide-users] Custom Symbols
If you don't need symbol size to scale, you could save it into a PNG
which you can then use as a symbol in Mapguide. This should give you
transparency and let you avoid having to create a font file.
Traian
From: Campbell, Keith A [mailto:keith.campbell at atkinsglobal.com]
Sent: Thursday, November 16, 2006 3:57 AM
Thanks Jason, I'll check these out.
Do you know if custom symbols can be created such that the background is
transparent. I think in MG 6.x symbols created as wmf and emf types
could have transparent backgrounds - back you did need to identify the
transparent colour in MG Author.
Keith
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 15 November 2006 17:46
Fontographer is apparently the premium font creation tool, but I've been
importing bitonal symbols into High-Logic FontCreator with a fair amount
of success. Using fonts is a pain, but it does add some flexibility
around making sure that web and desktop GIS users are seeing the same
thing.
http://www.high-logic.com/
Jason
Subject: [mapguide-users] Custom Symbols
I'm having some unexpected problems with custom symbols.
Firstly, I can add symbols into a symbol library, but some of them do
not display when added to a point layer. This happens with fonts also.
I've not identified what the difference is between the ones that display
and the ones that don't as yet - perhaps there is some limit on the size
of the symbol file?
Secondly, I can't add a custom symbol that has a transparent background.
Are fonts the only way to go with this (if you can get them to display)?
If so, does anybody know of a good application that will create true
type fonts?
<http://www.blackspider.com/>
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding. <http://www.blackspider.com/>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061116/be6b28a5/attachment.html
More information about the Mapguide_users
