[mapguide-users] Error Installing MapGuide Open Source in Linux!!!
Andy Morsell amorsell at spatialgis.com
Thu Nov 16 16:36:04 EST 2006
Have you seen this page on the Wiki?
http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_4
It may have some clues to help you.  The make check (step 7 you refer to in
the "Building and Configuring on Linux" document) looks like it is not
necessary so your subsequent make and make install may proceed just fine.
Andy
  _____
[mailto:julio.gutierrez at geospatial.com.co]
Sent: Thursday, November 16, 2006 11:25 AM
Subject: [mapguide-users] Error Installing MapGuide Open Source in Linux!!!
Hello:
I have problems in the installation of mapguide open source in fedora core
4. In the step 7 for install the server its show:
1 of 1 test failed
Make [4]: * * *  [check - TEST] Error 1
Make [4]: Leaving directory ‘/usr/local/mapguideopensource/Server/src/core’
Make [3]: * * *  [check - TEST] Error 2
Make [3]: Leaving directory ‘/usr/local/mapguideopensource/Server/src/Core’
Make [2]: * * * [check - recursive] Error 1
Make [2]: Leaving directory ‘/usr/local/mapguideopensource/Server/src’
Make [1]: * * * [Check - resoursive] Error 1
Make [1]: Leaving directory ‘/usr/local/mapguideopensource/Server’
Make: * * * [Check - resoursive] Error 1
What can I do?
Can you help me with this?
Best regards.
Julio Enrique Gutiérrez Gómez
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061116/c04759fd/attachment.html
More information about the Mapguide_users mailing list
