[mapguide-users] RE: Studio Enterprise and Web Studio Cannot Connect Randomly
Trevor Wekel
trevor.wekel at autodesk.com
Thu Nov 16 19:31:45 EST 2006
Hi Jason,
Does setting StartServers = MaxServers eliminate the connection errors?
Here's some more background on the IIS FastCGI extension.
Isapi_fcgi.dll does recycle the processes. Memory leaks will accumulate
for a while but resource consuming php-cgi.exe and mapagent.exe
processes should drop off after a while. The only catch is that
isapi_fcgi gives no control over how long the processes should stay
alive. For PHP, setting the following environment variables may help
roll the processes a little quicker:
PHP_FCGI_MAX_REQUESTS=500
PHP_FCGI_CHILDREN=1
These can be set by adding a registry setting under FASTCGI/.php
Environment REG_BINARY (0x0D delimited set of environment variables,
terminated with 0x00)
eg. PHP_FCGI_MAX_REQUESTS=500 0x0D PHP_FCGI_CHILDREN=1 0x0D 0x00
Thanks,
Trevor
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Thursday, November 16, 2006 5:12 PM
Cc: Trevor Wekel
Subject: RE: [mapguide-users] RE: Studio Enterprise and Web Studio
For anyone who's keeping track...
Setting the StartServers to a higher number did not seem to help me.
What has seemed to help was setting the StartServers and MaxServers to
the same number. I guess this is OK if you're not worried about memory
leaks or dynamic resource allocation on your server.
It looks to me like any time a MapAgent child process is killed on
Windows, the FastCGI ISAPI handler doesn't get informed about it, and
the first request fails. If you restart IIS after killing a process, you
don't get the error; a new process is just started up.
Jason
_____
Sent: Wednesday, November 15, 2006 12:41
Cc: Trevor Wekel
Thanks, I'll give that a try.
Apparently these can be set on a per-service level, under
HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI\.fcgi
And there is an "Environment" setting. Maybe this could be used to
overcome the problem with the PROJ_LIB variable not getting picked up?
http://viewcvs.php.net/viewvc.cgi/fastcgi-isapi/readme.txt?view=markup
Jason
_____
Hi Jason,
Telling isapi_fcgi and mod_fastcgi to spin up two servers might help but
I've had trouble forcing them to spin up agents. mod_fastcgi is
especially obstinate. Even under load it doesn't like to spin up more
than one agent. Here are the appropriate settings:
For IIS:
Increase the registry setting HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI
StartServers REG_DWORD 1
For Apache, modify httpd.conf and increase -minProcesses:
Change
FastCgiConfig -idle-timeout 120 -minProcesses 1 -maxClassProcesses 4
-multiThreshold 100 -singleThreshold 100 -killInterval 600
to
FastCgiConfig -idle-timeout 120 -minProcesses 2 -maxClassProcesses 4
Note: PHP uses a different configuration line and should already be
spinning up 4 processes:
FastCgiServer "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/php/php-cgi.exe" -processes
4 -idle-timeout 120 -
initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env PHP_FCGI_CHILDREN=1^M
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061116/1e116197/attachment.html
More information about the Mapguide_users
