[mapguide-users] WMS Provider on Linux?
Andy Morsell
amorsell at spatialgis.com
Fri Nov 17 17:32:42 EST 2006
I think this looks fine. Here are the results:
[root at localhost lib]# ldd libWMSProvider.so
linux-gate.so.1 => (0x00dc7000)
libFDO-3.2.0.so => /usr/local/fdo-3.2.0/lib/libFDO-3.2.0.so
(0x008c9000)
libFdoOws-3.2.0.so => /usr/local/fdo-3.2.0/lib/libFdoOws-3.2.0.so
(0x001e6000)
libWMSOverrides-3.2.0.so =>
/usr/local/fdo-3.2.0/lib/libWMSOverrides-3.2.0.so (0x0074a000)
libgdal.so.1 => /usr/local/fdo-3.2.0/lib/libgdal.so.1 (0x00dc8000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00111000)
libstdc++.so.6 => /usr/local/lib/libstdc++.so.6 (0x00c6d000)
libm.so.6 => /lib/libm.so.6 (0x00123000)
libc.so.6 => /lib/libc.so.6 (0x028c9000)
libgcc_s.so.1 => /usr/local/lib/libgcc_s.so.1 (0x00147000)
libxalan-c.so => /usr/local/fdo-3.2.0/lib/libxalan-c.so (0x06536000)
libxalanMsg.so.17 => /usr/local/fdo-3.2.0/lib/libxalanMsg.so.17
(0x00152000)
libxerces-c.so.25 => /usr/local/fdo-3.2.0/lib/libxerces-c.so.25
(0x02df2000)
libdl.so.2 => /lib/libdl.so.2 (0x0015a000)
libz.so.1 => /usr/lib/libz.so.1 (0x00185000)
librt.so.1 => /lib/librt.so.1 (0x00198000)
/lib/ld-linux.so.2 (0x00169000)
Thanks.
Andy
_____
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: Friday, November 17, 2006 12:58 PM
Subject: RE: [mapguide-users] WMS Provider on Linux?
If you run ldd on libWMSProvider.so. are there any missing dependencies?
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, November 17, 2006 1:39 PM
Thanks Jason, but that was included as part of the build process. Tom's
instructions at
http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_4 includes
that step. I have other third party providers, such as GDAL, working fine on
the same installations.
Andy
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, November 17, 2006 10:32 AM
I don't think that the MapGuide installation instructions that I looked at
told you that you had to run the install option against the build_thirdparty
script as well as the build script. This messed me up on Windows anyway.
Jason
_____
Sent: Friday, November 17, 2006 10:27
Subject: [mapguide-users] WMS Provider on Linux?
I recently built FDO 3.2 and MapGuide Open from subversion on Fedora 4.
When I built FDO, I included all of the optional data providers. Everything
seemed to build fine.
But, when I try to create a layer using the WMS Provider, I get the
following error at the server:
An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 201 in file
FdoConnectionManager.cpp
In the fdo-3.2.0 directory, there are a number of libWMS* files and
providers.xml does have an entry for the WMS provider. I am experiencing
this same problem on two different Fedora 4 boxes.
Thanks.
Andy
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061117/a59e0931/attachment.html
More information about the Mapguide_users
