[mapguide-users] WMS EPSG
Scott Hameister ScottH at mPower-tech.com
Mon Nov 20 16:11:24 EST 2006
Is this why I only see a couple CoordSys's in WebStudio?
Is there a Library with all the Major Coordinate systems in it, like all the
State and UTMs that I could download and fix this?
-----Original Message-----
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Monday, November 20, 2006 2:58 PM
Subject: RE: [mapguide-users] WMS EPSG
Brad,
You will need to update the Proj.4 "epsg" file with the definition of
EPSG:102190 and it should work. I tried to google this and couldn't find
it so I'm not sure what it looks like in order to test it.
The Proj.4 file "epsg" is located by the path specified in the
environment variable "PROJ_LIB" and you would want to add the 102190
entry to the end of the file, ie: ..\nad\epsg
Thanks,
Bruce
Sent: November 17, 2006 5:03 PM
Subject: [mapguide-users] WMS EPSG
Hi folks: simple question:  we are using BC Albers EPSG 3005 for our
initial
map projection.  Will  we be able to view  a WMS BC Albers map layer
that
uses  EPSG 102190?
thanks
View this message in context:
http://www.nabble.com/WMS-EPSG-tf2657673.html#a7413308
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
