WMS EPSG
BradM masonb at dfo-mpo.gc.ca
Mon Nov 20 16:15:55 EST 2006
thanks Bruce,
If our initial  map is epsg 3005 shouldn't  we be able to view wms sources
in epsg 3005? So far we can only make a successful connection but cannot
view anything.
Bruce Dechant wrote:
> Brad,
> You will need to update the Proj.4 "epsg" file with the definition of
> EPSG:102190 and it should work. I tried to google this and couldn't find
> it so I'm not sure what it looks like in order to test it.
> The Proj.4 file "epsg" is located by the path specified in the
> environment variable "PROJ_LIB" and you would want to add the 102190
> entry to the end of the file, ie: ..\nad\epsg
> Thanks,
> Bruce
> -----Original Message-----
> From: BradM [mailto:masonb at dfo-mpo.gc.ca]
> Sent: November 17, 2006 5:03 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] WMS EPSG
> Hi folks: simple question:  we are using BC Albers EPSG 3005 for our
> initial
> map projection.  Will  we be able to view  a WMS BC Albers map layer
> that
> uses  EPSG 102190?
> thanks
> http://www.nabble.com/WMS-EPSG-tf2657673.html#a7413308
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/WMS-EPSG-tf2657673.html#a7450816
More information about the Mapguide_users mailing list
